TwinTurbo.NET: Nissan 300ZX forum - 2nd what Damon said, also - check your timing with
Subject 2nd what Damon said, also - check your timing with
Posted by 91Z32TT on March 31, 2011 at 1:07 AM
  This message has been viewed 277 times.
In Reply To Timing Belt Replacement posted by gripmaster on March 31, 2011 at 12:25 AM
Message a timing light. That's the easiest spot to start. If they didn't line the CAS back up perfectly the timing could be retarded significantly and causing the symptoms you describe.
In addition to that, if you find that the timing is within spec (15 degrees +/- 2 degrees generally) AND you notice that the CAS is rotated all the way over on the adjustment one way or another, you likely have a belt that wasn't installed correctly.
